or something.
Let’s draw an image to use an etching tool on — first source a suitable material:
EDIT: pre-cut 5mm thick acrylic sheets are no longer available from Carbide 3D — any similar material may be used.
Then begin drawing:
or something.
Then begin drawing:
Since we need multiple overlapping parts and outlines, this is a good chance to make use of the new Layers feature in CC521:
Once the drawing is complete:
It is necessary to work out the toolpaths and decide upon the figure–ground reversal aspects and so forth.
If we use a black piece of acrylic, then it should be possible to get silver by drag-etching areas — worst-case, if need be we can apply silver paint to those areas.
